How to fix screws around hinge
I’m trying to figure out what to order to fix my 13in laptop with an i7-1165G7 processor if that matters. The hinge of the right side of the screen (by the power button) snapped. Also, the screw by the power button wont tighten OR stay in the case - it falls right out. I think what it was supposed to screw into snapped off the keyboard cover: Imgur: The magic of the Internet
Most of the screws on the bottom cover screw into something that looks like this: Imgur: The magic of the Internet
Is there anyway to fix the screws not screwing into the keyboard cover?
I was going to order that hinge replacements for the broken hinge - that’s obvious. But maybe I need a whole new bottom cover or keyboard cover too and maybe those include the hinges.
@Tucker_Hoog Give our support a shout here. They’ll ask you for some pictures, but will be able to direct you to what you need pretty quickly.
