Installing the Wifi Module
I am not sure if I did something wrong but my laptop does not seem to be detecting my wifi module even though both white and black cables are connected. There is a slight bend in the white cable which I’m hoping isn’t a problem.
What OS are you using? If windows, have you installed the driver bundle here listed at the bottom of the page here: Windows 10 Installation on the Framework Laptop DIY Edition - Framework Guides? Note that there are more recent versions but they are still in testing. They can be found here: Framework Laptop BIOS and Driver Releases
If you’re running linux the steps will vary by distro, but generally if you are on a recent kernel the card should work.
