Wireless network card not detected
Hello,
Is there something special to do when connecting the wireless network card ?
In the slot and both wires white and black connected in the appropriate position.
I first thought that the retaining plate might be causing a short so I added a layer of tape to the plate to prevent contact.
Tried reconnecting that component twice, to no avail, Windows will not detect the installed hardware,
Please help.
If you are running Windows 10, you’ll need to install the Framework Drivers for the WiFi card to work. Install Windows without an internet connection.
https://downloads.frame.work/driver/Framework_Laptop_driver_bundle_2021_07_08.exe
Also…
https://guides.frame.work/Guide/Windows+10+Installation+on+the+Framework+Laptop+DIY+Edition/92?lang=en
