Framework 13,
intel 12th gen.
running: Pop!_OS 22.04 LTS
An exciting new problem I have discovered. Yesterday, seemingly out of the blue the framework internal keyboard and touch pad stopped working. The power button continues to function. and the laptop seems otherwise unaffected. I am typing this on it now actually, with an external keyboard and mouse, both of which work fine. The exact circumstances of the fault are unclear. The laptop was connected to an external keyboard, mouse, and monitor via a dock. I sent it to sleep, disconnected it, and opened it at home. I’m not sure if the keyboard and touchpad stopped working immediately after awakening it, but it was certainly soon after.
The internal keyboard and touch pad provide no input at all, not even at boot. This problem has persisted through multiple restarts. and through me carefully disconnecting and reconnecting the touch pad cable. However, the power button does work, suggesting that the cable connection isn’t really at fault.
Things I have tried:
- restarting
- restarting after being powered off for 8+ hours
- disconnecting and reconnecting the touchpad cable while powered off
Though I have found a myriad of keyboard problems online, I haven’t seen any with this exact issue, still here is the output for dmesg | grep i8042 which seemed to be relevant to lots of similar problems:
[ 1.515105] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.516539] i8042: Warning: Keylock active
[ 1.520604] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.520608] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.520743] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 6.950943] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input4
Although I can use the computer connected to an external device, its a annoying and I would prefer the internal keyboard and touchpad work.
Thanks for any help!
Update It seems likely this is an operating system problem and not a Framework specific problem.
I got both the touchpad and the keyboard to work briefly. I noticed that in my display settings the system showed only the external monitor, and there was unexpected behavior when opening the laptop with the external monitor connected.
Normally when the external monitor is connected and the internal one is off (closed) it still reads the internal monitor. Now it no longer does. Even more unexpectedly, when the internal monitor is open it remains off and is not detected. In the past it would activate and automatically switch to the internal monitor as the primary display.
I noticed when opening the lid that the display would briefly appear in the settings. I closed and partially reopened the lid and for a few seconds while the display setting was reading the internal monitor both the keyboard and the touchpad functioned normally.
I even crrupted smthing and nw the external keybard n lnger accetps the letter “0” (zer here because i cant type the letter) prgress!
ext i eve maaged to switch the “o” with the letter ext to “m” o the keyboard. Much progress.
Away it seems likely this is a OS problem, sice the keyboard will work uder very specific coditios
