I was trying to put in a pre-order for AMD 7040 version, but there is no Klarna financing option.
If I try to place an order for 12-gen version, then Klarna is available at check-out…
How to go about it? When the time for full payment comes, will I be able to use Klarna?
I would contact support about this. It’s possible that it’s not available because it’s a pre-order, but only support can say for sure.
Yes, it is because it is a pre-order. No, I don’t think when final payment is needed you will be able to switch to Klarna as FW will want to charge the same original payment method.
