Laptop won't power on unless i plug in AC power
It’s not a ‘laptop’ problem but an Intel 11Gen issue which of course ‘most’ laptops don’t use.
Ahem… Most laptops’ use CR2032s that last years. Because of the Intel bug it would drain in 6 weeks. The rechargable battery was put in to avoid having to replace batteries (by ‘most other’ vendors too). Framework had a design issue because of which it drains faster than they anticipated. I’ll cut them slack for that, h/w design is incredibly complex and very hard to revert after you’ve done a production run. Admit it and move on. Geez!
Hiding behind a response deep in a 295 message thread, 7 months after original report, isn’t acknowledgement, it’s hoping that no one finds out. That’s precisely why I started a new thread!
The only problem I’ve seen attributed to 11th Gen is that when CMOS/RTC loses power, the processor may end up in a bad state that requires a hard reset (which, at that point, is apparently requires removing the main battery as well – the CMOS battery was already depleted, so it already removed itself. That’s one part I don’t understand about the fix: didn’t the system not just spontaneously perform a hard reset to create the problem?)
I understood that the fact that CMOS/RTC draws so much power to be maintained and/or that the main battery cannot help ito keep it powered, s entirely down to Framework’s design.
The alleged silicon bug in Intel 11th Gen makes the problem much worse and some production errors in brackets/faulty button cells gave a lot more attention to the defect, but the fact that the system can fail to power on with a healthy, charged main battery after being off for just weeks is really surprising (in a bad way). That’s not normal for or expected of laptops.
Without the bug people would probably have complained less, because plugging in the laptop would hopefully immediately restore power to CMOS, so apart from some settings being wiped, the system would boot; and if a laptop has been on a shelf for a month or so, you would probably plug it in, just to be sure.
Could you elaborate on this? Is this something available through the marketplace?
You just have to request it through support.
Hello all,
Please do not force our hand in locking this thread. We’ve explained, in detail, what options are available for any customers that purchased Framework Laptop 13 (11th Gen Intel Core) or 11th Gen Intel Core mainboards and have an RTC Battery that has been deep-cycled to the point of no longer holding a charge.
  • Contact Framework Support
  • Provide Order Number or email used on order
  • Provide image of mainboard with serial
  • Ask for either replacement RTC Battery or RTC Battery Replacement
  • If RTC Battery Replacement, you acknowledge that you have soldering experience to solder the single wire to the mainboard
If this thread goes off the rails or gets contentious, we will lock it down. This thread remains open for Community help/troubleshooting, but this is not a thread for debating the options available.
I’m having this problem with my Framework Laptop 13 (11th Gen Intel Core). I’ve been considering upgrading my laptop using Framework’s official upgrade kit.
My question is: Will upgrading using the upgrade kit solve this problem for me? Or will I still have to look into one of the options above for the RTC battery replacement?
Follow up question: Is there a specific upgrade path that would fix the problem? (For example upgrade to AMD as opposed to Intel 13th Gen)?
Welcome to the community!
If you upgrade the mainboard, it would solve the problem. An Intel 13th gen or AMD board wouldn’t have the RTC battery issue.
As this is a monster thread is it possible to get a tl;dr of the important information? I’ve not been able to read all of it so it’s not yet clear to me how I can determine/verify that this is the issue affecting my machine or what the difference is between the two solutions you mention.
Thanks!
Yeah, the 11th gen framework laptop has a design flaw with the RTC battery (the coin cell battery on the motherboard). There are two distinct ways the button battery can fail:
  1. If the laptop is left unplugged for a while, the coin cell battery will drain over time. If left for too long (sounds like a couple of weeks), then the battery will reach a low enough charge that the laptop will not boot.
  2. Over a longer period of time (took me 1.5 years), regardless of how often you use your laptop or how often you plug your laptop in, the coin cell battery degrades. This eventually reaches a state where your laptop will not boot.
When the coin cell battery hits this failure state, your laptop will not boot. There are two distinct possible problems that arise:
  1. The most common symptom is just the laptop refuses to boot unless you plug in your laptop. If this was caused by the laptop being unplugged for a while (#1 above) then you can leave your laptop plugged in for 24-48 hours to recharge the coin cell battery which should return your laptop back to a normal working state. If this was caused by the button battery degrading (#2 above), then you will need a replacement button battery.
  2. There is a very low percentage chance that you hit a bug (caused by Intel) where the laptop will not boot even when plugged in. If you hit this, then you have to do a motherboard reset.
Framework has offered two resolutions to these problems:
  1. If your coin cell battery has degraded (#2 in the first list) then they will send you a free replacement battery. This will return your laptop to a normal state but the battery will degrade just like the first one so you’ll still be at risk of this problem happening again in the future.
  2. If you want a permanent fix, Framework has designed a fake battery you can replace your button battery with, but this is a VERY RISKY procedure and it involves soldering. My overconfidence with this is what killed my 11th gen board, so be careful. The replacement battery doesn’t have rounded edges and the flimsy battery holder will shatter at the slightest provocation. Installing this fake battery allows your RTC circuit to be powered by the laptop’s main battery. You can browse this thread to see the graveyard of 11th gen motherboards from attempting this fix. It is strongly recommended that you hire a professional to do this fix rather than attempt it yourself.
This problem does not exist on any other framework laptops, only the 11th gen, because all their subsequent laptops have been designed to be able to boot without the button battery (and their newest laptops ship without a button battery at all).
So to put it all into a table:
Laptop left unplugged for 1+ weeks Button battery degraded over a long time despite frequently plugging in laptop
Boots with a charger Leave your laptop plugged in for 1-2 days to recharge your battery Contact Framework for a free replacement button battery
Does not boot with a charger Perform a motherboard reset and leave your laptop plugged in for 1-2 days Perform a motherboard reset and contact Framework for a free replacement button battery
Finally, if you want to source a replacement button battery yourself instead of grabbing a free one from Framework Support, you want to purchase an ML1220 which is the rechargeable version. You DO NOT WANT the CR1220 (the far more common but non-rechargeable version).
Yes I’ve got an 11th gen laptop. Based on @Tom1’s post (thanks for this!) it looks like I’m in the camp of completely degraded button battery - it refuses to boot unless I’m plugged in. So will contact them for a new one.
