Loose microphone switch
Nothing big, just a minor issue:
My microphone switch is very loose and can be easily shifted left and right without any pressure, while the camera switch is quite rigid, which I prefer. It’s also easy to leave the microphone switch in the middle, which likely isn’t a good thing either.
Is there an easy fix to this, where I take the bezel off and press some piece into place, or something similar?
Thanks
I found this thread, but it doesn’t solve the issue either.
As described over there, the difference remains even if I take the bezel off and move the switches in the detached state.
I have the same “looseness” of the mic switch. Been that way since day one. It never bothered me or switched on its own, despite being tossed in my backpack often. I figure if it became an actual problem in the future, a replacement bezel (of a likely later revision released in the future) will fix it. I suspect it is a well known issue at FW at this point.
Ah okay. Yeah, I just noticed it recently and it bothered me a little. I’ll just ignore it and may get a new bezel, if they ever add better colors. If the purple wasn’t as light as it is (Lavender), I would’ve gone for that instead. Anyway, thanks ^^
