Possibly dumb question here..
(there’s no subforum specifically for expansion modules so posting on discussion related to the laptop I have)
The microsd slot module. When the microsd card is fully inserted, is it mostly flush to the side of the module & spring loaded, or does it stick out of the side? Couldn’t figure it out from product photos.
I have the full size SD card module, works great for photography etc.
I’m thinking about possibly buying a steam machine when it comes out and the idea of being able to store some of your library on a microsd card and pop it out and move it between devices is appealing but I don’t want to risk breaking the sd card ![]()
