I have been working on 6 versions of the per key RGB keymaps but this is the only one that is sorta polished and have not found any conflicts so far. ANYONE please take a look and if you got any changes that would increase speed or use less data for same tasks it would be appreciated. I also have ones for the macropad that work for me but i need to polish those too before uploading. you can see my macropad in the images on the README file.
I worked out how to change the RGB’s brightness like how backlight step works for animation brightness. and also now you can have per key RGB or turn off the RGB brightness and the animation colors will be active and you can configure in the RGB layer.
This is a video of the keymap navigation.
