I booted my laptop with windows 10 and afterwards with the Marching Framework Bundel. Everyting worked well and i had wifi but 10mins after that i lost my Connection top network. The Diagnose is saying this:
Hi @Adrian_Droz. You can find a helpful guide through this link: WiFi troubleshooting steps
If this continues to be an issue for you, I would recommend submitting a ticket to our support team here: Framework | Support so they can ensure your laptop is performing as intended!
Thank you and stay safe!
I had this problem. And after some suggestions from the team i discovered that one of the wires from the wifi module has become loose. So i put it right and then it worked fine.
I hope yours is as easy.
Paul
