Hi All,
I have a number of weird problems with charging my laptop (11th gen, Windows 11, diy edition). At times, when I plug in my charger, the light will not turn on, or flicker, or turn off after a few seconds. The laptop will not charge then. Worryingly, the charger itself will then stop working for a few minutes on other devices, too. After a few minutes, the charger will work again. So it seems that some sort of protection in the charger is triggered which resets after a few minutes. I have observed this behaviour with two different Macbook chargers (61 watts), so I think I can rule out the individual charger being the problem.
At other times, the charger works, but differently on the two USB-C ports I have. On one port, it shows that the laptop is charging, but the battery still slowy drains while using the laptop. On the other port, the laptop charges as usual.
This makes me think that there is something wrong with the USB-ports.
I have updated the bios to 3.10, installed the driver package, reset the motherboard as detailed in the support, and checked whether the battery and touchpad connectors are properly seated, but the problem remains.
Does anybody have an idea?
