[RESPONDED] Spurious clicks while using touch pad
I’m having more and more issues with my touchpad. I don’t quite know when this started because I typically use my laptop when docked, but this is getting more and more noticeable when it isn’t, to the point where it’s irritating enough that I’m looking at fully mouse-less operation (which is something i try to do anyways)…
The symptoms are hard to describe clearly, but typically the problem is with spurious clicks: the desktop is registering clicks when I am not intending on clicking anything. Typing this, for example, I am always nervous that my thumb trips over the touchpad… So far, it hasn’t done so in this session, oddly enough, but I’ve seen pretty bad patterns where it would click randomly on the page, and even select text areas which is pretty catastrophic as then the next thing you type destroys whatever it is that was selected.
I’ve also seen scrolling fail miserably. Just now I was browsing through my Nextcloud calendar listing and couldn’t scroll down (with a two-fingers gesture) without having NC open an even randomly, thinking that i clicked the even while I was just scrolling.
Is the touchpad defective? Or would this be a software problem?
In the body of your post, please include those following details.
  • OS: Debian GNU/Linux 12 (“bookworm”)
  • Laptop: 12th gen intel
  • Desktop: Sway/custom desktop
I have a similar experience with my touchpad feeling to sensitive to my thumbs while typing on linux. I do have “disable while typing” enabled in hyprland but frankly it feels like it makes no difference.
Given the limitations of configuration options for libinput when using wayland/ hyprland I’m not certain what and how to test at all. From past research it feels a lot like software limitations.
see just now the touchpad just completely stopped working for a few seconds, it would just not move the mouse cursor at all.
On bookworm do check with evtest and choose touchpad see if touch and clicks registers no problem.
Also check with Ubuntu 22.04 live to see if issue is alswo visible their or not.
cheers! :slight_smile:
i just remembered this is not the first time i have issues with the trackpad, see:
but that issue was different: the touchpad was doing cracking noises and the click (not tap) was just not working reliably. here is different: i have spurious clicks that seem to be related to taps, not clicks.
i should also mention that part of this might be issues with my wayland compositor (Sway). it has a “disable-while-typing” setting (dwt) that I have enabled, but it could not be working, which would explain at least some of the “spurious palm touch” phenomenon. but the “touch while scrolling” issue feels like something different, related to the touchpad itself, hardware.
Hi, sorry for the delay.
Touches don’t register in evtest.
It is visible in Ubuntu 22.04 as well.
In fact, I can’t seem to even trigger a right-click at all with the touch pad there, but that could be a limitation of GNOME/Ubuntu. In my normal desktop (Sway, in Debian trixie), three taps does emit a right click.
The problem is also that the pad is now all “mushy” and doesn’t click at all anymore. So taps are the only thing that works, and “triple-tap-drag” doesn’t work, so i can’t right-click-drag. (I know this sounds weird, who does that, but i certainly do…)
Anyways, the touchpad seems broken, can i get another one? is this covered? do i write support? next steps? :slight_smile:
i’ve escalated this with framework support.
And support delivered! The touchpad was broken, I ordered a new replacement (50$), they shipped it within a day, it arrived within 4, and I put it in place within half an hour:
whoohoo!
