[SOLVED] Bluetooth: Intermittent connection between Razer mouse
Having a #bluetooth connection issue spefically with a #Razer Orocho V2 mouse. This mouse worked fine for over a year with a Macbook Air as well as a Desktop PC over Bluetooth but ever since I switched over to a 12th Gen Framework running #Windows 11, after pairing for the first time, it doesn’t always reconnect after a reboot or when the machine is in sleep mode.
Machine: 12th Gen Framework w/ 2x8GB Crucial Memory, WD Black SN770 500GB
Device: Razer Orochi V2 w/ latest firmware
Steps tried:
Other than that, I’d assume the two should work right out of the box as I have no issues with it on other machines.
Installed latest AX210 Bluetooth driver from the Intel website and it seems to have resolved the issue. Will continue to perform further testing.
Case closed. Seems to be working fine after the Intel driver install.
