Are the three dots and reply button gone for anyone else? I have tried disabling Brave shields to no avail. I have to highlight part of a reply, click quote, and clear the message box as a workaround. I just got member privileges if that could be related. I can’t bookmark replies either, which is really inconvenient.
I can do all of these things also on Brave but members should be able to reply, that is just a basic thing for a forum after all
Everything looks good from the admin panel for you?
There was a Discourse security update the other day, on the 16th. I have not seen any issues related to that but I’ll bring this up.
Suggestion: clear cookies, clear cache, log in again?
@Fraoch Admin panel?
He is a mod, he was checking his admin panel to see if you had revoked privileges
Ah, I see, thanks. By the way, I did indeed logout, clear cookies and cache, and log back in. Unfortunately, it didn’t help.
For me, it is the same
Any content/adblockers active? Sometimes they assume stuff is supposed to be hidden when it isn’t.
