Yesterday, I came back to my laptop after it had been hibernating. I had an external dock hooked up to it (which I usually don’t), which includes a USB-C power supply from my macbook.
My laptop initially would not turn on. I unplugged the dock, and it still would not turn on. I then hooked up my regular USB-c power supply, and it turned on and resumed from hibernate like normal.
However, I noticed my touchpad was completely unresponsive and after a few minutes, the center of the touchpad became very hot (too hot to touch!). Restarting did not help.
I can now seem some dis-colorization in the middle of the touchpad. The touchpad still gets extremely hot after just a few minutes, and is still unresponsive. Everything else appears to be working as expected.
My first concern was that there is something wrong with the battery. and it was the battery underneath that was overheating, however, I took the keyboard/touchpad off, turned on the machine, and again the touch pad gets hot, the battery was cool to the touch.
My plan is to purchase a replacement touchpad, but I am wondering if this may be indicative of some other issues.
What do you all think? should I be worried about anything else (like replacing the battery)?
Fedora 41
InsydeH20 Rev. 5.0 HFW30.03.05
Which Framework Laptop 13 model are you using? (AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™)
