Since your experience has matched mine exactly (same config), borrowing a link to this for another thread.
@Matt_Hartley go for it. The only difference I see based on your /etc/default/grub is that I am using luks encryption which is reflected in my /etc/default/grub. I have also seen even greater stability after the 3.06 beta BIOS update. Really if you are buying a processor that is less than one year old and plan on running linux, you have to be willing to live on the bleeding or not so bleeding edge
I agree with every single word said here. All of it. ![]()
Yeah, I have LUKS on my Fedora 37 install (11th Gen) Framework lappy.
Have a great holiday weekend!
@Matt_Hartley enjoy the holiday break, new year projects are around the corner.
So I finally experienced a hard freeze last night. Almost three weeks without one. So what changed…well about a week ago I removed the i915.enable_guc=3 from my kernel parameters. I am currently on 6.0.15-300.fc37.x86_64 and I don’t think this was a regression, I have been reading the changelogs with every release. I am enabling this kernel parameter again to see how long it takes until the next hard freeze to see if this is a contributing factor. Logs were inconclusive as to pointing to a cause, just the usual bluetooth, gnome settings, after a screen lock. Yes I have narrowed it down to screen lock and not suspend. Apparently this was also the source of my losing my external displays attached to my dock, with no discernible pattern. I now use suspend instead of screen lock and so far the displays are working as they should. I realize guc is enabled by default for adler lake processors but huc is not. Since huc deals with CBR rate control on SKL low-power encoding mode and a web browser is a common theme with the freezing issues (and I have Firefox open in the background with every freeze), I am going to see how this plays out now. I had two weeks of no freezes with it on previously. I am goinng to leave it in place for a longer period of time and then remove it again, and see if I get my weekly visitor.
Some additional observations regarding suspend instead of screen lock, I no longer lose all my bluetooth devices, they remain connected instead. I really need to dig into how gnome screen lock works.
Okay, now this is interesting and someplace I can work on testing. I will share this with my Fedora contact as well.
Ah, there we are. Dock and external displays…we used to see a LOT of this at my previous job. So this seems to happen at screen locking?
The screen lock would not always disconnect the displays, but after a prolonged screen lock it was very likely. Additionally what was wasa interesting to me was that the ethernet connection did not get dropped, however bluetooth devices would.
I disabled hibernation, and hybrid-sleep in /etc/systemd/sleep.conf and modified /etc/Upower/Upower.conf to PowerOff on critical just to make sure the system was not trying to hibernate or anything else of the sort while screen locked. These modifications had no effect on the undesirable behavior. I then removed the Super+L shortcut reassigned it to systemctl suspend and removed automatic screen locking behavior in settings.
This had the desired effect. I am also hopeful it will further reduce the freezes as every freeze I have had has been after a recent screen lock. I just figured screen lock would turn into a suspend given sufficient time, guess I was wrong. Regardless there is definitely something wrong with screen lock in Wayland. I have now used suspend to “lock” my screen at least a dozen times, and the external displays come back up every time. With screen lock I would have had to remove the thunderbolt cable at least 4 times by now to get them back. This is something that I was even seeing on my old Thinkpad T480s, so I don’t think it is hardware specific.
So for you at least, this appears to have been the cause/workaround resolution? I agree, there is definitely something not right with screen lock in Wayland with external displays attached. I have not experienced any issues with merely the laptop display itself.
Neither have I. Come to think of it all of my freezes have occurred while docked as well. None have occurred with just the laptop, being directly charged by a charger.
Docks, a wonderful asset until they’re not. ![]()
While this is not amazing, it’s likely giving us a general direction in which to keep poking at.
This may be a red herring. I’m somewhat confident that I’ve seen freezes with no dock/external monitor attached.
In general, it seems that the circumstances under which this occurs are rather hard to determine. We’ve seen a lot of “I did x and now the bug doesn’t appear anymore”, which then later turned out to be wrong. (It may very well the case that certain circumstances make freezing more likely to occur – but I don’t think this will take us further to the root cause.)
So I did some more digging today. 1) GUC and HUC are enabled by default on Fedora 37 no need for the kernel parameters 2) The following error:
i915 0000:00:02.0: [drm] Resetting chip for stopped heartbeat on rcs0
i915 0000:00:02.0: [drm] *ERROR* rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
appears to be the culprit, the dates match my memory of hard freezes. 3) Also experiencing non-fatal errors in intel_ddi_sync_state, which may be related.
Additional trobleshooting revealed that multiple monitors may contribute to the crashing. Logs are clean when the laptop is not attached to the dock. Once it is attached the number of errors in the logs enters the level of spamming. No extensions and entering the activity overview creates a bunch of errors. I am going to do additional testing here with usb-c connections and active displaylink adapter to see if it helps.
Another contributing factor may be hardware acceleration in browsers, however I believe this should be resolved once the new intel-media-driver hits rpmfusion. It is already available on Archlinux so I expect this will drop wthin the next week or so.
@Matt_Hartley Sorry, I didn’t see that you had replied to me until yesterday!
I actually just experienced the issue again a few minutes ago, so I looked at the journal and found this before I put my computer in sleep since that seems to unfreeze it:
Jan 06 08:05:18 framestancies plasmashell[6071]: libva info: va_openDriver() returns 0
Jan 06 08:05:18 framestancies plasmashell[6071]: ATTENTION: default value of option mesa_glthread overridden by environment.
Jan 06 08:05:18 framestancies systemd-timesyncd[1288]: Timed out waiting for reply from 220.158.215.21:123 (1.opensuse.pool.ntp.org).
Jan 06 08:05:28 framestancies systemd-timesyncd[1288]: Timed out waiting for reply from 51.38.105.7:123 (1.opensuse.pool.ntp.org).
Jan 06 08:05:32 framestancies systemd-logind[1348]: Power key pressed short.
Jan 06 08:05:32 framestancies dbus-daemon[1920]: [session uid=1000 pid=1920] Activating service name='org.kde.LogoutPrompt' requested by ':1.13' (uid=1000 pid=2068 comm="/usr/bin/ksmserver")
Jan 06 08:05:32 framestancies dbus-daemon[1920]: [session uid=1000 pid=1920] Successfully activated service 'org.kde.LogoutPrompt'
Jan 06 08:05:39 framestancies systemd-timesyncd[1288]: Timed out waiting for reply from 162.159.200.1:123 (2.opensuse.pool.ntp.org).
Jan 06 08:05:48 framestancies kernel: usb 3-7: USB disconnect, device number 3
Jan 06 08:05:48 framestancies kernel: usb 3-7: new full-speed USB device number 6 using xhci_hcd
Jan 06 08:05:48 framestancies kernel: usb 3-7: device descriptor read/64, error -71
Jan 06 08:05:49 framestancies kernel: usb 3-7: device descriptor read/64, error -71
Jan 06 08:05:49 framestancies kernel: usb 3-7: new full-speed USB device number 7 using xhci_hcd
Jan 06 08:05:49 framestancies systemd-timesyncd[1288]: Timed out waiting for reply from 204.2.134.162:123 (2.opensuse.pool.ntp.org).
Jan 06 08:05:49 framestancies systemd-timesyncd[1288]: Contacted time server 17.253.2.123:123 (2.opensuse.pool.ntp.org).
Jan 06 08:05:49 framestancies systemd-timesyncd[1288]: Initial clock synchronization to Fri 2023-01-06 08:05:49.931245 CST.
Jan 06 08:05:50 framestancies kernel: usb usb3-port7: attempt power cycle
Jan 06 08:05:50 framestancies systemd-logind[1348]: Lid closed.
Jan 06 08:05:50 framestancies systemd-logind[1348]: The system will suspend now!
After looking further through the journal to yesterday, at a time when it also happened, I found this common thread:
Jan 04 10:33:46 framestancies plasmashell[22493]: ATTENTION: default value of option mesa_glthread overridden by environment.
However, I’m not entirely sure this is helpful, as it’s a message so common throughout my log (appearing about 2000 times in the last month).
I also did see your message about the best course of action being perhaps just to wait for an update, and that Red Hat may be working on it. But hopefully this late response is at least somewhat helpful to finding this. Maybe there’s something else in the log I posted that could be a clue.
Please see this post and keep an eye on it for Monday. I’m compiling a list coming soon and will then use it to look for common threads. Hard freezing on Fedora 36 with the new 12th gen system - #319 by Matt_Hartley
Thank you!!
Everyone who is experiencing freezing, please reply with this outline below so I can get this into a spreadsheet and track this down for the folks at Fedora. Please use this format. Thanks!
Fedora 36 or 37:
12th gen or 11th gen:
Kernel version:
Gnome version:
Using i915 fixes, if so, which ones:
Has this been tried yet and if so, any difference:
Applications running in foreground or background when freeze occurs:
What if anything is attached to your Framework; docks, (BT, IR, wired) mouse, keyboard:
Fedora 37
12th gen -7-1260p
Kernel 6.0.17-300.fc37.x86_64
Gnome 43 Wayland
No fixes used no additional kernel parameters outside of blacklisting the light sensors.
Not planning on using any kernel parameters which decrease battery life unless absolutely necessary
Applications running in foreground or background when freeze occurs: Firefox, Evolution, Gnome Control Center, Gnome Terminal, and Quodlibet.
What if anything is attached to your Framework; Thinkpad Thunderbolt 3 Dock (Gen 1), Logitech Bluetooth Mouse M557, 1 (1920x1080) and 1(3840x2160) display
Additional Notes:
Using Wayland Per Display Scaling
Errors seen when hard freezes occur:
i915 0000:00:02.0: [drm] ERROR rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
intel_ddi_sync_state errors
journalctl gets spammed with Can’t update stage views actor and anytime I use activities overview with external displays I get JS ERROR: TypeError: workspace is undefined with a bunch of preceeding and following Object .Gjs_ui_workspaceThumbnail_ThumbnailsBox (0x559a0c31d570), has been already disposed — impossible to get any property from it. Essentially every super key press is a about 50 lines in the log of it complaining but doing what it is supposed to do.
All freezes have occurred while docked or attached to peripheral devices. I have had no freezes when it was just the laptop. My last freeze was on Dec 26 2022 at 21:01 EST. I suspect the intel_ddi_sync_state errors will resolve when the intel-media-driver updates. I have seen a drop in occurrence frequency, as the kernel has been updated. Much of this may not be just intel graphics issues but regressions in Gnome to issues that were common when the new overview was rolled out.
Hello all,
Long time reader, first-time poster. I know this thread specifically mentions “Fedora,” but I would like to suggest that this is a more general issue. I’m having this screen resolution jumping and jittering and freezing issue on my Framework Laptop running Pop!_OS. And it is driving me bonkers. It does it for me on both X11 and Wayland.
Here is a link to an example video:
And here are my details:
Hardware Model Framework Laptop 12th Gen Intel Core
Memory 32.0 GiB
Processor 12th Gen Intel® Core™ i7-1260P × 16
Graphics Mesa Intel® Graphics (ADL GT2)
Disk Capacity 1.0 TB
OS Name Pop!_OS 22.04 LTS
OS Type 64-bit
GNOME Version 42.6
Windowing System Wayland
Kernel version 6.0.12-76060006-generic
Using i915 fixes No
External monitor Yes
This happens only when I’m not using the recommended (highest) resolution for the Framework Laptop display. I have low vision, so I need to run at lower resolutions to be able to use my system comfortably.
Thanks,
Thomas
Hello and welcome!
Why not? This solved the issue for someone else.
