PER SUPPORT REQUEST:
Configuration
- Framework Laptop 16 (Batch18)
- Operating System: Windows 11 Pro
- System: Ryzen™ 9 7940HS
- Memory: DDR5-5600 - 64GB (2 x 32GB)
- Storage: WD_BLACK™ SN770 NVMe™- M.2 2280 - 500GB
- Storage: Western Digital SN740 NVMe™ - M.2 2230 - 2TB
- Expansion Cards:
- USBC
- 1TB
- USBA
- USBC
- HDMI
- HDMI
I am having an issue with a USB 1TB expansion card. I am using WSL2 with Debian and the mount point for the expansion card is /mnt/f. I have no issues in WSL2
However, F:\ in windows 11 pro, I looses the drive on shutting the laptop and reopening it.
When I turn on the laptop from a full shutdown I receive, sometimes the dialog below:
I do not receive this all the time… Its spotty at best.
If I use the windows spec F:\ it works without fail on startup. It is only when the device sleeps and then I come back to work on it windows explore, PowerShell and dos or any other app (ie: Typora) that has a reference to F:\ fails. Note this does not happen all the time and in some cases it is not experienced it for days.
Windows startup does not always display the USB Device Not recognized.
Since everything for the most part operates I am leaning toward this being a driver issue. Which I have updated about a week ago. But tonight I lost the F:\ drive after about an hour when the laptop went to sleep.
The fix is a reboot… However, I have also issued Disk Management and restored its operation.
My question is simply is there any issues of this in the knowledge base or community matching my experience here?
