Maybe it’s time we have an unofficial poll to see what people would like to see as the next step.
What are some of the reasonable outcome you would like to see as forward options for the poll?
…and I think this could go beyond just looking at this issue. Maybe look at it from a general product hardware issue. Somewhat similar to what Louis Rossmann said around right to repair, it’s not just about one product, one issue. It may not affect you now, for the product you got, but you would still want to have the ‘option’ for right to repair, maybe for another product, maybe for a family member…etc.
So, if we look at the ‘repair’ side of things (i.e. not throwing the board away), is there a potential option that there could be a ‘mod kit’ to over come this issue (be it a combination of software and hardware)? Something like the old days where you have mod kit for your PlayStation, or ThinkPad x220 1080p mod…etc
@Louis_Rossmann, would this be something Chris might be interested in working on as a side project…together with Framework and see if this could be fixed? Maybe a bounty for a solution?
The other thing I would like to see is for Framework to update the marketplace listing for the 11th gen board, to include details / warning about this issue.
Also, just want to point out that the “sell it” suggestion from Framework Support (allegedly, by a poster above) is not a solution, and if it’s a solution, it’s a lazy one at best.
If Framework really stands behind repairability and sustainability, then I believe the correct course of action is to come up with a ‘fix’ in the form of a repair or modification service to the already existing boards that are already in the wild.
Maybe Framework supply a replacement board with the recharge links to the battery socket disconnected and a proper battery? I can live with having to swap in a new one once every couple of years?
Surpising it’s not an issue for me, but it would have been nice to know and not have to find out on the forum. Luckily I did find out here so am forewarned, and building home near cliff or a near a river that can flood is a clear and present danger.
This issue was not foreseen nor could reasonbly be expected.
The RTC battery, once charged should last for two or three weeks. If it isn’t charged then sure power will have to be supplied externally.
If the voltage gets very low then plugging won’t do much if anything and then the RTC battery can be removed to let it recover enought to get the BIOS to come alive.
So this will only occur is some circumstances, it is not a thing that everyone will have to do. Given I use mine daily then I’m hopeing it will never happen.
Back to your residence comparison, if you don’t use a house for a few weeks regularly or only for a day or two every few weeks it won’t be that surprising to find someone may have squatted it, or even sold it.
Think someone in this thread mentioned a car analogy (non-EV).
The CMOS battery is like the car’s 12v battery. Imagine that you have to jumpstart your car everytime you want to drive it? This was particular the case for old cars (old car batteries) during covid time because of the work-from-home, shop once a week, go out less, only travel within your community / short distance.
If the ML1220 connector was implemented not as a clip, but as a two-pin connector…we could have just opt for a wider button battery…something like an ML2020 (same thickness as the ML1220). It has 45mAh capacity instead of 17mAh (nominal).
But of course, this isn’t a fix for why it’s draining so, seemingly, quickly.
Looking at the specs for ML1220 (from Panasonic):
It has a continuous drain of 0.03 mA. From a 100% health, and 100% charged…that means the battery should last around 23 days. Assuming the Framework laptop doesn’t drain the battery faster than that.
So, assuming that drain rate of 0.03mA…the ML2020 could last 62 days.
And, if the clip mechanism wasn’t there, there’s likely enough height to fit an ML2032…which could last for 90 days.
Agree. Hope Framework will have a solution for this…or at least one that can minimize the occurrence of this. In the meantime, I’m going to wait for the next gen board reviews.
