Konsti
June 30, 2026, 5:14pm
1
Today I received my Laptop 13 Touchscreen. Replacing the old screen was easy and I also get screen output (I’m even writing this on the laptop), but I don’t get any touch inputs.
I have not found any drivers to download, fwupdmgr doesn’t show me anything I could install, what could I try?
Here are my specs :
Operating System: Ubuntu 24.04.4 LTS
Kernel: Linux 6.17.0-35-generic
Architecture: x86-64
Hardware Vendor: Framework
Hardware Model: Laptop 13 _AMD Ryzen 7040Series_
Firmware Version: 03.18
And I’m running wayland (if that changes anything)
K0nr4d
June 30, 2026, 5:33pm
2
Same issue for me on CachyOS.
I’ve also installed the beta BIOS which should enable the 13 Pro features.
Highlights
Added support for Framework Laptop 13 Pro features - Enabled compatibility for the haptic touchpad, touch panel, and 74W battery.
Updated the audio verb table to support the new speakers in the Framework Laptop 13 Pro chassis.
Updated AMD PhoenixPI-FP8-FP7_1.2.0.0f.
Fixed an issue where the system was unable to boot from partially locked self-encrypting drives (SEDs)
Fixed an issue where the Battery Extender status was reported incorrectly following a reboot, hibernation, or shutdown…
The KDE settings page also reports that no touchscreen is detected.
Same for lsusb which doesn’t list the touchscreen. (At least I think this is where it should be shown)
Besides that the screen is working great at the 120Hz feel sooo smooth!
Just wanted to clarify, you are not using the LTS kernel, correct? You are using the modern kernel release? Tracking this.
K0nr4d
June 30, 2026, 6:25pm
4
No, I’m using the current stable kernel.
7.1.2.3-cachyos
I’ve also made sure that all my packages were up-to-date.
Got it, that is helpful.
So to be incredbily annoyingly obvious (forgive me).
No stylus, your fingers do not work with the touch screen?
If your fingers are not working with the screen, do me a favor, please go into BIOS, press F9 then F10 to save/reboot.
If it still not working, please open a support ticket and link to this thread please.
Konsti:
I believe that you need 3.20. 3.18 is from four months before the announcement of the new hardware, and does not contain the required configuration to support the touch panel.
Konsti
June 30, 2026, 7:14pm
7
Immediately did that, after Konrad wrote here. Am now on 03.20 but the touch input still doesnt work.
Konsti
June 30, 2026, 7:21pm
8
Even though you did answer to Konrad here, I just resetted my BIOS setup to default values and now the touchscreen works.
For anyone reading this later, my troubleshooting steps were:
Install the BETA Bios (3.20) by following the instructions in Framework Laptop 13 Ryzen 7040 BIOS 3.20 Release BETA
Reset BIOS by going into the BIOS setup utility () and pressing F9, then F10 there.
I recommend making photographs from your current BIOS setup values to set them again after the reset and try whether the touchscreen still works!
K0nr4d
June 30, 2026, 8:38pm
9
Yep, also worked for me!
Now I can finally get my finger grease all over my clean new display. ^
Having a similar problem with mine but I have the newer Ryzen AI 9 HX 370 mainboard, and the latest stable BIOS update it includes all the FW13 Pro stuff so no need to go Beta.
It would be great if the instructions QR code on the box went to actual instructions that include “a BIOS update may be required” instead of a 404 page.
Thanks, this resolved it for me.
My scenario was
13" 7040U
Installed the 3.20 BIOS Beta from Windows
Got back into windows/etc
Shutdown & installed 13" Pro display
Started up Windows, no touch screen.
Checked Windows update, and found a HID to install, still no touchscreen.
After the BIOS load default, things then worked. So at least for me, installing the beta 3.20 ahead of time didn’t prevent this from happening.
So i am running an 11th gen board which hasn’t had a bios update since 2025. Do we think that i need to wait for a new 11th gen Bios update for the touchscreen part to work?
Where is 3.20, I can not find it. Thanks
3.20 for Ryzen 7040 is still in beta and is available under this thread Framework Laptop 13 Ryzen 7040 BIOS 3.20 Release BETA
I’m not sure what other BIOS’ are out there for mainboards to support touchscreens.
Konsti
July 3, 2026, 6:05am
16
I have the Processor Intel(R) Core™ i7-8086K CPU @ 4.00GHz, 4008 Mhz, 6 Core(s), 12 Logical Processor. Any other ideas why my new touchscreen wont work?
Can you double check which mainboard/processor your laptop has? 8th gen Intel chips were never shipped w/ Framework. (As far as I can tell)
Per your request:
FRANDA0014 Framework Laptop 13 DIY Edition (12th Gen
Intel® Core™)
Keyboard: US
English (1st
Gen), System:
Intel® Core™
i5-1240P
$819.00 1 $819.00
FRANRXWD0A WD_BLACK™ SN770 NVMe™ Capacity: 1TB $129.00 1 $129.00
P2032 DDR4-3200 Capacity: 32GB
(1 x 32GB)
$160.00 1 $160.00
FRANCEPH0B Power Adapter - 60W Power Adapter
Plug:
US/Canada
$49.00 1 $49.00
FRACCKBZ01 USB-C Expansion Card Material +
Color:
Aluminum -
Silver
$9.00 1 $9.00
FRACCABZ01 USB-A Expansion Card $9.00 1 $9.00
FRACCHBZ01 HDMI (1st Gen) Expansion Card $19.00 1 $19.00
FRACCDBZ01 DisplayPort (1st Gen) Expansion Card $19.00 1 $19.00
FRACCMBZ01 MicroSD (1st Gen) Expansion Card Expansion
Card: MicroSD
Expansion Card
Ed
This is the update for 12th gen: Framework Laptop 13 - 12th Gen Intel Core BIOS 3.20 Release BETA
You will want to look at why your machine is pretending to have a limited edition 8th gen Intel CPU from 8 years ago.
