Got Windows installed, driver package installed, BIOS updated, Windows installed, and a few programs installed. All good so far. I never would have thought I’d especially care for the RGB effects on the macropad, but there are some pretty neat affects. I especially like the stuff that is reactive to button presses.
I haven’t looked super close, but I haven’t noticed any display pinching from the bezel. I still have some programs to install. The case definitely runs hotter than the AMD Framework 13, though there is also the difference between Windows 11 (FW 16) and Fedora 39 (FW 13) that may come into play a bit. The fans can get pretty darn loud, which they did while updating Windows. Obviously, still not a full review or anything and I haven’t used it much, but just a few more thoughts.
Hopefully everyone else gets there’s soon and the setup process goes as smoothly as mine has so far.
My FW16 is taking the same route to the Netherlands, I almost suspect that FedEx triangulates flights between China → Germany → France → Back to China or something, because like you said, It wouldn’t make sense to fly it all the way back when it’s so close to it’s destination.
FedEx’s tracking shows mine is expected to be delivered on Monday so we’ll see how that goes I guess.
I just checked this morning, yeah, it said it was held up in France and has arrived in Stanstead this morning - looks like it’s in customs currently, says it’s going to be delivered Monday morning - I could get to stansted in about an hour! Shame no pickup as could go get it now!
They’ve certainly been on a lot of planes to get here!
I can’t wait to get my hands on the FW16
(Ordered with these specs:
DIY
Ryzen 7
dGPU
Int. English keyboard (no RGB)
Numpad
2x USB-C, 2x USB-A, HDMI, Audio and Network
Hoping my “luck” with laptops doesn’t repeat itself again (the old laptop dying within 2 weeks after the new laptop comes in) haha
Mostly because I can partly because I am going to use this to replace my Alienware x51 r2 but I still want to take it with me and I know my peripherals will be different using it as a desktop and on the go. I figure if I don’t use them all with this computer when I buy another I’ll use it with that one
That’s smart. They’re relatively inexpensive and are much smaller than traditional USB-to-X adapters. I would buy spares too if I had a 2nd Framework laptop.
Got to assemble my laptop today. Put the single 32GB DIMM I got with it into slot 1 and it came up after half a minute or so. Installed Ubuntu since, but have a lot of work in front of me as I’m migrating from Windows to Linux for the first time. The hardware looks good, ethernet, wifi and speakers are working. Haven’t had time to test anything else yet.
A single touchpad module would definetely look and feel better, the top left and right edges of the touchpad module want to lift slightly even if it is level when outside of the machine.
Received my laptop assembled and downloaded windows 11pro only issue I has was windows 11 installer didn’t recognize Wi-Fi & restarting the network loader in the task manager wouldn’t work so I used the Ethernet jack updated driver when done fixed the no Wi-Fi issue everything seems to fit fine there’s slight height differences with the spacer but it’s minimal and if you play with them they feel flush!
Just find out I perched three different color of spacer……every color by only one….
And my plastic interposer cover is little broken some how, which not functioning
Should I grab support?
Same. Our laptops are probably in the same shipment crate. I wonder why it went back to France though. It’s not like we don’t have enough baguettes or croissants here… Maybe it wanted to go back for another helping of escargot?
